- Dec 20, 2012
- 9,422
I'm going to guess this play is due to non-existent preload. It is likely that your thrust washer is too thin. Make a thicker one and make sure the preload nut is actually applying pressure to the upper spindle bearing. The only vertical play that should exist is that allowed by the internal bearing clearances in your spindle bearings.
