Cleaned up the spindle with some round stones. At least the rough stuff is gone. Searched for my MT4 dead center, and couldn't find it.
. I thought I had one when I bought it. Found an "
MT4" dead center that I bought. Another never been used tool. Did the smurf thing, tapped the dead center into the spindle and then popped it out. More or less what I expected. Nearly 0 contact. Just the ring around the spindle nose. There was a small amount of contact at the base, but overall total contact maybe 5%. The missing blue in the second picture is not because of contact, it was because I didn't apply the blue to the very end.
View attachment 399775View attachment 399776
From the marks on the spindle and on the morse taper sleeve earlier I suspected that these bits of tooling are off spec. The taper is not MT4, it is steeper than MT4. Looking carefully at the dead center, the external packaging says MT4. On the actual dead center it is marked MS4. Is this some unknown Chinese standard? I can't find any reference to a MS taper. Maybe it stands for morse sleeve? But a dead center is NOT a morse sleeve. Either way, the dead center I have has little contact along the sleeve. Instead, all the forces are concentrated at the very taper edge at the spindle nose.
I will clean up the morse taper sleeve (MT4 to MT2) to do the blue check. Bet it will have similar (nonexistent) contact.
Disappointed in this. Why would someone make a MT that wasn't really a MT? This was nicely ground, can't imagine any meaningful manufacturing economy. Have to think these were (both) rejects, scooped up and resold as compliant.
