Definitely not the fun part. I'm thinking we should all have an appropriately attired, (3" heels and short-shorts) curvaceous and mute young shop bunny to do that kind of work. Mike
The motor is in place and it is time to order a flat belt. The build up is much more compact with this solution than the original design. But all old parts are saved and could be used again if wanted.
This is almost the end of the project. The Bahco lathe was tested today without remarks I tested it up to 3000 rpm on the spindle and there are no vibrations. This rpm is too much I guess for normal operation with glide bearings, but I wanted to stress it a bit at this test.
I haven't got the right drive belt yet so I used about 5 layers of 3M silver tejp as a temporary solution. I'm surprised how well it work. The inner layer was oriented up side down with some overlap.
Now that's a new use for Duct Tape I've never thought of.
Great job on the lathe.
I wish I had done the same to mine when I first got it, but I was anxious to make some chips.
I guess I'll do the clean and spit shine on the next one.
Project closed by the two last pictures. I made a wrench for the Tool Post nut and the two locking screws. It is made from a new Impact Socket, threaded to M12, and a junk shaft from the bin. The shaft is secured by Loctite 270 (permanent).
