Made up and threaded 8 lifter/spring retainer pieces for the valves.
I made minor adjustments to the lifters so each cylinder would be inline with the other cylinder on that bank for the overhead cam clearance.
I am tired of laping valves and taking the heads off and on but I do have compression on all four cylinders now.
I added some springs and here it is.
Cam shaft brackets are next.
Thanks for looking
Ray
wachuko and Boswell thank you for your kind words.
This engine will be taller and longer and wider than the flat twin was even tho I have reduced the thickness and length of many of the components.
It just keeps growing.
