You didn't say anything about actually using the knurler. If you have used it and your results are like mine then you will stop worrying about those clips. This tool is so hopelessly flexible that I found it to be virtually useless. The knurl wheels don't track straight since the whole tool twists as soon as the wheels are engaged with the work. Sorry to be disparaging about your purchase or to the tool seller as they have some decent tools. This just isn't one of them in my opinion. A knurl tool which works for me is the home built version by Tom's Techniques.My new Shars scissor type knurling tool arrived today.
The dies are held on shafts secured with very small retaining rings I've never seen before.
I have three different kinds of retaining ring pliers and none of them could get a grip.
Is there an actual way to get them off without breaking them?
How the heck does one install them?
I did manage to remove them by breaking them, and I did have a set of rings that included the same type ring in the right size. I did manage to install them, but it was almost impossible. There must be a right way.
I think they are called G-type retaining rings.
Must be some exotic steel. I used to have a pair of very small electronics needle nose that I ground down and left a small ridge on the tips. They worked good, but some rings still broke. I have an assortment of external and internal snap rings to replace them. If they are too small for that I usually go to the local hobby shop and look on the aircraft hardware section for them.
