- Nov 24, 2018
- 239
Those are good options. A smaller lathe might not be able to use the negative rake trigon rougher, but your lathe has plenty of power.For inserts, the carbidedepot.com tech guy recommended the following for machining carbon and alloy steels:
and
Personally, I don't like 80 degree tools for finishing as they are prone to dragging chips due to the clearance angle hugging the workpiece, but not an issue if you don't mind compensating by angling your QCTP. I like to keep mine square and get clearance from the insert geometry. Different strokes for different folks.
