- Dec 26, 2015
Yes, those are the Kennametal equivalents. Those should serve you well. Make sure you get inserts suitable for your materials. The CCMT versions should have a small nose radius for finishing operations.
The rule of thumb for finishing cuts is the depth of cut must be at least half the nose radius of the insert. So you can answer your own question. If you plan to take finishing cuts of 0.008" or more, they are fine. If you try to remove 0.002" with those, the surface finish is likely to be total crap because the insert isn't consistently engaging in the material. I use that same insert in my shop on lots of varieties of steel, but to hit tight tolerances, I use the balanced method I talked about earlier in this thread with a link to a video on the technique. I would never try to hit tight tolerance by creeping up on it with light skim passes.
