- Mar 26, 2018
- 8,410
At times like this, I'll upload the video to Youtube and add the link to the video in the thread.Ok, can’t upload a vid, too big.. I’ll keep looking for options.
Just my 2 cents.
PerfectAt times like this, I'll upload the video to Youtube and add the link to the video in the thread.
Just my 2 cents.
He can't reach the inside SHCS for removal. I too am a bit stumped.To remove the saddle is pretty easy. Block the gear box Assy. And lead screw so when it’s disconnected it’s supported.
You need to remove the plates that are bolted to the bottom of the saddle that keep it locked down to the lathe bed.
Unbolt the Allen’s on top the saddle that connect the saddle to the gearbox.
That should get you to the point of separation.
Personally I’d replace the bent screw. A new one shouldn’t be to bad. Good luck on your repairs!
Boy, that's good to hear.It's a new lathe. I personally wouldn't be happy with stray replacement parts. Eisen is a good company and great to deal with. I Purchased a lathe from them and it was totally destroyed in transit. I rejected the machine on delivery and they sent a replacement right out. I'm sure they will bend over backward to get you fixed up.
I can’t see any physical way to even GET to it regardless of length of Allen wrench… The last time I removed my apron I cut off an Allen wrench to fit.
