- Mar 25, 2013
- 4,615
That is the menu I am using. What I am saying is that I can only select a 1 or a 2 in that box. I cannot select a 4 or a 5. Keep in mind, you do not enter using a number key. You press SET and it toggles through the available options. I tried changing the DRO to MILL and GRINDER but I still can only select 2 axes. Clearly they are limiting the DRO display capabilities since more axes are more expensive. I'm sure it just a software limit with identical hardware.
