- Oct 31, 2016
- 2,645
My bushings and gears were the same. Stuck together. I originally thought that they were some how bonded together. Particularly the two 48 tooth gears. After soaking with PB Blaster and WD40 the bushing slid out. These gears are not very strong. Be careful trying to get the bushing out. If you should happen to break a gear the gears are available on Ebay.
If you need to cut metric threads you can replace the two 48 tooth gears with a 52 tooth and a 44 tooth gear. Or it might be a 54/42 gear combo. My memory fails me at times. There are articles in the documents about doing this. There are also threads that discuss making this modification. I did it to my lathe.
