- Jan 18, 2018
- 314
Will, you are right, there is a striking similarity between the micro chuck and the Dorian knurler. You are also correct that the Dorian does have dovetails(and gibs).I believe what @Cadillac STS meant was a DIY knurler project. That Dorian knurler looks based off a micro chuck like Sherlines & Taigs use except the Dorian knurler appears to have dovetails for the "jaws".
When you knurl with the Dorian knurler you set the desired closed diameter with the set screws on the collar, then use the red knobbed lever to open and close the knurler. As you feed the closed knurler onto the stock it’s rotating motion keeps the device closed and forces the knurl wheels into the the stock.
