- Mar 26, 2018
- 2,724
Not trying to argue. For a CNC conversion, you'd need some steppers. Automation Technology makes some good low cost kits as does Stepper Online.
For the control, you can pick Mach 4 (my choice), LinuxCNC, or CNC12 (for use with Centroid Acorn). You would then pick a compatible control board (I use the Warp9TD Ethernet Smoothstepper with Mach 4).
Add some wire, an enclosure, learn about electrical wiring practices and safety, add limit switches, estop, spindle control, and a PC. Then you have a starter CNC. It would probably cost you around $1500 to realistically get started, with some of that covering the mechanical components you'll need to connect the motor to the screws.
