Cnc hardinge dv-59?
is there is everything provided in this kit except mach 3?
Kind of? I wouldn't recommend using Mach 3 or a parallel port interface. Both are antiquated, hence my recommendation for Mach 4 and the smoothstepper motion controller.
That kit is also missing limit switches and an estop as well as any interface to the machine elements you require (like spindle start/stop).
Yup thats the board. Again, I recommend Mach 4 over Mach 3. Both work with that board. Spend a few days reading about this stuff before you go buy it.
IMHO the biggest barrier (and reason not to proceed) will be the fact that the Hardinge does not have a lead screw.
it has 6 inches of travel on the top slide and all of the parts that i will be doing are about 1 to 4 inches in length and i want to learn about cnc nad make tops
