- Oct 16, 2019
- 6,582
You can do it with a 4 1/2" angle grinder. Just take your time. I've done more pieces than I can count from 1/4" stock up to 1" that way. Below are pictures of two benches I made out of 1" plate. I used a 7" grinder on those and a boatload of grinder disks. Each bench top had free-hand cuts on three of the four sides. It took quite a bit of time to cut each one, but the real challenge is slowing yourself down and not rushing it.
I would suggest you order the plate at least 1" (preferably 2") over in each dimension to avoid hardening.
Regards,
Terry
Nice tables Terry!
The oversize advice is well taken.
