- Oct 16, 2019
- 6,582
I bought 2 chunks of 3/8 x 2' x 4' HRS plate to make drill press and hand tapper base plates. Both were shear cut, which means they were slightly bent. I have an Evolution circular saw, so I bought their metal cutting carbide blade and cut them down.
You do need face protection from the hot sparks, and it made a mess, but it sliced right thru them. I used a length of angle for a straight edge to guide the saw. To make the three plates I probably cut about 6' total. Blade is noticeably dull, but still going. I just sanded and filed the cut edges, as didn't care if they were true square.
I did have to fool around in the HF 20 ton press to more or less straighten them out, so burned edges may save you that hassle.
That’s a good point actually!
I would never have thought of that.
