And so it begins, new PM-30MV...
I changed mine out with some brass hex bar on the x and y axis. I did a press fit with some cap screws and loctite 609.
First chips.
WOW, this is soooo nice. Was so excited I forgot the parallels. :)
X-Axis mount for glass scale. The pocket is for a spherical washer to adjust out the slight slope.
Next up is drill and tap two M5 holes into the cast iron base.
You are soon going to wonder how you survived without a mill. You will soon be visualizing parts hidden inside of solid stock.
Just love this thing. Reminds me of way, way back in high school metal shop class. Nothing like the smell of way oil.
Y-axis 5um glass scale mounted.
Still have to disassemble again to trim/paint base mounting bar. And add a few tapped holes for chip shield. While the glass scale has nice double seals, there's a slight gap between bar and base that needs to close less that area becomes filled with chips and other mess.
Spherical washers worked great. There's a pair between mounting bar and base. Another pair between encoder and its mounting plate, then a pair where plate mounts to saddle.
Heads up for other recently received PM30-MV owners. The M6 socket head screw bolt that tightens the z scale end to the spindle was missing on mine. Never noticed it until now.
A M6 x 25 socket head screw works with a snug fit.
