- Jan 22, 2011
- 8,031
I was just thinking about your balancing weights, Mark. By making one of the three longer, and hence heavier, aren't you introducing an out of balance condition to begin with, regardless of the wheel itself? Seems like this may work against you. Not that you couldn't compensate with the other 2 weights, but I was taught in general to make balancing work with the lightest weights possible. Since the wheels are supposed to be pretty close when they get to you, I hope you don't need all that much steel.
