Actually I haven't had the chance to do anything with it over the last few weeks. We've been super busy at work, I do have stock on hand for making the brake cam, but it's going to be a few weeks now before I can even think about working on it. I expect that it should only take a couple of hours or so to make it and the handle, and I was hoping to have it done before now, but luck has not been with me when it comes to spare time. I do have it on the top of my list, however, so it will be the first thing I work on once I can get back in the shop.
Maybe Terryworm has some news on the brake cam??
Well, stay cool and look forward to hearing from you all.
Here's a couple links for general info on your mill as well as other machines. http://www.lathes.co.uk/index.html
Here's the sub-link for Clausing mills. http://www.lathes.co.uk/clausing%20vertical/
Terry is correct about those fine feed gears, mine were stripped out when I gotit. Lucky for me, I'd found another complete head on eBay I had bought too as a"Just in Case" since I knew from research that parts were hard tocome by and the gears were good in that one, just swapped them out.
I'll be watching this thread too since my brake doesn't work. I haven'tdissassembled mine to see what's wrong with it yet.
Terry, what's your opinion on having an operational brake beyond fast stops forsafety reasons ? Any other use for it you've came across ?
BTW:
Terry, I mightbe convinced to part with the spare drawbar if you desire.
