- Jan 16, 2020
- 8
Here is something that you will find useful, namely a link to the downloads section with two PDFs covering the Clausing 8520/8525 mills. One is a scan of the original owner's manual/parts list, the other is a document created by one of our members on rebuilding the head of one of these mills. Both valuable to have.
http://www.hobby-machinist.com/vbdownloads.php?categoryid=43
PS: The belt sizes are listed right in the parts listing drawings, which is where I got the correct ones in the first place. My mill did not have the correct belts on it when I got it, plus one of the bearings in the jackshaft pulley was junk, and the other was probably not far behind. I ordered replacement bearings from McMaster-Carr and picked up the belts at the local hardware store. Mine also has four teeth stripped off of one of the fine feed gears, and I plan to make a replacement in the not too distant future. The handle was also missing from the brake on mine, so I made a new handle for it and picked up a simple plastic knob at the hardware store downtown.
I also just noticed that the brake handle and possibly the brake cam shaft are missing from yours. Let me know if that is the case and I can either make one and send it to you or I can dimension it out, draw it up, and send you the drawing so you can make your own.
