How much were the bearings? Grease ?
Many people are afraid to do it yourself - Like I have said for years "machine Rebuilding and scraping is easy IF you have a pro help you"
You learned to scrape in a week, now you know how to rebuild a precision spindle.
Next time someone in here wants to repair / rebuild a spindle pass on what we taught you.
If you don't have an infrared thermometer to check the temp run it until it gets hot to touch, shut if off and let it cool down to warm, run it again, repeat until it doesn't get hot. 140 F is the max it should not reach. Once you get the headstock back in the column then mount the mag base on the outside of the spindle housing and put the indicator on the end of the spindle and push or pry with a 2 x 4 to check the thrust.
Good Job!! Be sure to call or write Craig and thanks him. I told him the other day when I retire to the scraping school in the sky, he can teach the classes. Rich
