That's why I said to take pictures or make a sketch so you could line up the new bearing dot where the old bearing dot was. Also I suspect the bearings are mounted back to back configuration on opposite sides of the spindle shaft to get good thrust.
Hopefully the new bearings will show which side goes in toward the other bearing. The old ones have ""Thrust Here" on the outer race.
These bearings were also so packed with grease it was oozing out both sides.
After talking to Richard's buddy, he said, when you get the new bearings, clean the factory thin oil by using brake cleaner, do not spin the bearings!!, blow out with air then grease with Kluber grease.
Put a small amount of grease on each ball, about the size of a sewing pin ball or a bit larger. Excessive grease will cause heat.
The price of the bearings are $150 to $685 each, depending on your source. I was assuming $500 and up each. And yes, they are precision ABEC-7 bearings.
SKF is the manufacturer. I guess they bought out MRC.
FYI
(Edit- I was misquoted from one source. It was $685 each, not $150. I ordered a set for $210 each.
This is the grease. Richard gave me an Amazon link for it.
ISOFLEX TOPAS NB 52 and ISOFLEX TOPAS NB 152 are rolling and plain bearing greases based on a synthetic hydrocarbon oil and a barium complex soap. The special barium-soap thickener used in the ISOFLEX TOPAS NB 52 and 152 greases offers good load-carrying capacity as well as resistance to water...
www.klueber.com
