Working on my DIY Tool Post Grinder-Ugh
What size bearings ?
15mm ID
32mm OD
9mm wide
ABEC 3
14,000 RPM
Press fit on shaft should be between. .0005-.0008"
OD is a clearance fit, but it needs to be perfect. What, .002" clearance? .001 on each side?
And won't develop a curl along its length as you peel away the outer layers. That's the big benefit when tenths and single digit thousands count.
SKF 6002s If you need any , I have quite a few extras . My contribution to your grinder . :)
Did they have a bake sale at work??
Dang dude, that's what I ordered.
No, wait those are much better. The rpm range is 10,000 higher. Plus "
  • Accommodate radial and axial loads in both directions"
I don't know if McMasters say this.
You never cease to amaze.
Jeff . 5 on their way Friday . Always following along . :)
