- Mar 26, 2018
- 8,707
Oh believe me I’ve considered it.Your more persnickety than me. I would just run a center punch around the i.d. and smack the bearing in. Mike
I found this video that I remember watching a while back.
I’m gonna play around with this method.
For a home job so would I . A little Loctite retaining fluid and I think it would be good to go .Your more persnickety than me. I would just run a center punch around the i.d. and smack the bearing in. Mike
A couple of spring cuts are needed if you're trying to hold .0005 or close to that . Hard to dial that in on a cross slide . Are you making an internal grinder Jeff ? Pics ?I sneak up on it with a sharp HSS tool bit. Cut the last .003" and blow it by .001" ish.
I'm sure Jeff knows this, but one can take some pretty fine cuts by angling the compound. I've done 0.0001" cuts by setting up the compound to go in 1/10 the dial movement. Just look up in your trig table to find the angle when sine(angle)=0.1. I don't remember the value, I just calculate it on my phone. 5.74 degrees relative to the spindle axis with remove 0.1 x the dial. The tool has to be so sharp you bleed looking at it! But it works. At least it does on 1215, 12L14 and 1144.For a home job so would I . A little Loctite retaining fluid and I think it would be good to go .
This is all I got so far.For a home job so would I . A little Loctite retaining fluid and I think it would be good to go .
I know the trick but I forgot to try it.I'm sure Jeff knows this, but one can take some pretty fine cuts by angling the compound. I've done 0.0001" cuts by setting up the compound to go in 1/10 the dial movement
I was thinking 3" OD and haven't got that far on the ID.What size wheels are you planning on using ?
