- Jun 5, 2023
- 71
Why backwards? I face my backplate by putting it on as it would normally be used.
First face the face, use light cuts. Use power crossfeed to do most of the facing, at the end go manual .
You should be less than 1/2 a thou ideally 0 run out on the face. Then do the registration boss for the chuck.View attachment 498240
So the backwards is because its not seating right against the spindle and no amount of facing it on chuck side will fix that. I guess the argument can be made that if the chuck side was faced to the miss-seating then the miss seating does not matter.
That "gap" is just a shadow in the picture. Thats the threaded spindle coming through but its fairly tight fit there. There is no real gap.
I do think I will do this face as well after a pass on the otherside. Question, the face you have marked "do this second" has a tight fit right now with the chuck. Is it a problem if I reduce that and loosen the fit? I guess the bolts still hold it in place but will it cause any problems?
