- Jun 12, 2014
- 5,127
I would do a parameter reset to stock, and then do just a few parameter changes at a time and check everything. Set A001, A002 to the control source and A003 to your motor base frequency. I would set A044 to 03: (Sensorless vector (SLV)), put in the motor parameters H003 and H004. Then run the motor Auto-tune H001, and after that is completed change H002 to 02 (Auto tuned data). Just start with the simplest changes, if you still have a problem then something is probably defective. Just to confirm the VFD is single phase input model and is sized accordingly for the motor FLA? Also check your line voltage, it should be at least 10V above the motor specified voltage.
