- Aug 23, 2013
- 966
Re: Scraping QCTP
Erik, thank you for the information. Tim
I think you should. Scraping will guarantee you have flat surfaces, and that will eliminate rocking due to bad surfaces. I would say 10 ppi would be plenty. You will want to make sure you get some significant (50%) spotting coverage. You can get that fairly easily by wet stoning after you scrape it flat.
I think the type 2 holder has a v groove to hold a round bit. The v is not so wide that you can't use flat tools, but it can be inconvenient when mounting small tools -- they may not be as wide as the v.
