- Nov 17, 2020
- 1,723
I need some larger calipers… but most of them are stupid expensive…
Was able to get this one for 85.00 delivered home…. 13-14” not sure… Starrett 123
Still looking for one that is 24” but reasonably priced…
Starrett 123EMZ-24 Master Vernier Caliper, 0-24"/0-600mm Range, .001"/0.02mm Graduation *USED/RECONDITIONED*
Item Description Range: 0-24"/0-600mm Graduation: .001"/0.02mm Accuracy: ±.0005" per foot Accuracy: ±.01mm per 300mm Half as many bar graduations as conventional single-vernier tools Easy to read Machine divided graduations Tight, smooth fitted slides No glare Starrett satin chrome finish Long...
shop.idealprec.com
Fowler 52-008-024-0 Extended Range Dial Caliper 0-24" Range .001" Graduation
Ideal Precision Range: 0-24" Graduation: .001" Accuracy: ±.003" Jaw Depth: 3.375" Depth rod .500" internal measuring nibs Dial hand completes one revolution per each .100", large dial—easy to read graduations Inverted covered rack prevents dirt accumulation in rack gear teeth. Self-contained...
shop.idealprec.com
Precision Brands 75104 Carbide Nib Jaw Vernier Caliper, 0-24" Range, .001" Graduation *USED/RECONDITIONED*
Item Description Range: 0-24" Graduation: .001" Screw-type adjusting nut allows for fine measuring adjustments and lock nut holds measurements Fine tool steel construction Carbide tipped jaws Made in the United States *Quality Used Item - professionally inspected, refurbished (if needed) and...
shop.idealprec.com
there is more there, just have to look
