We worked on our finds, the Nikken live center and the jacobs chuck.
Buffed the crud from the chuck, found a key not quite big enough but works, it was stuck from sitting, as soon as it moved it turned by hand.
Wire wheel cleaned it up nicely, good to go.
The center is more interesting.
It was a set of slots for a cap to go on to hold a center drill. No cap, will need to find one.
Put it in the vise, point down and it is solid.
Has a missing cover, can see inside so let oil soak overnight, it moves a couple degrees.
Solvent and blowing out no change.
Not sure how it goes together, and it was only 2 bucks so Experiment.
Can see a shaft like thing with a center in the end.
A center punch into the center, hold by hand the taper with point down, couple light taps with small hammer and it moves.
First the part with notches comes off.
Next the center shaft slides out.
Some crude and rust but intact.
It is made to service, good design sort of.
Cleaned most, then soaked in lye, yes, lye...it got all of the crud off and left clean metal.
A bit of stoning to center then the rollers on the bearing.
The main bearing stays in the taper part and center is inner bearing race.
There are roller bearings in black of the center for better leverage, great design.
At first it turned rough.
Stoed the center, better.
Stoned the rollers much better.
Used small knife to bind a roller then use that to scrape the outer race that we cannot get to.
After this, without any oil it turns real smooth with occasional feel of minor drag.
Packed it with Grease and good, real smooth.
For our hobby shop it will be fine.
The open end needs a plug, about 3/4 inch, metric, what size?
Just happen to have hub from international Fire truck that we will use for something else, looks close, wheel stud threads right in, so getting a bolt at the supply house for that.
Just need to find the cap...
LM5 - L5
Sent from my SM-G781V using Tapatalk
