- Dec 18, 2013
- 2,643
Well, I've never replaced bearings in a motor. I guess I will watch a couple of youtube videos and check it out.
and
Yikes!The Finnish price above is without VAT (25,5%).
This is something we all say the first time. If I can do it you got this. Plenty of support here if you have issues.Well, I've never replaced bearings in a motor. I guess I will watch a couple of youtube videos and check it out.
well the dust collector is going back. WTF are they thinking. It says it will do 2 1/2 inch vac hoses. well it does with the single adapter they provide, it necks it down to 1 1/4.. Stupid stuff. I want 2 1/2 full suction. Very disappointing. I could get it to work, but for $49 I can get a Oneida 2.5 dust deputy.
Ok, but the vac hoses still don't attach to the off sizes they used. An external adapter slides right off, so the hose won't stay on. The adapter the provided grabs less than 1/8 inch of the hose end. Just bull crap. And yet Oneida's appears to support the 2.25 hose end, and so does the home Depot dust topper.i want my cake and Edith too.The 1-1/4" neck down is there for a reason, as a (pseudo) critical orifice. Cyclone action and dust transport is a function of velocity. At the same volume, velocity is inverse to duct cross sectional area. There is a limit though, the faster the air moves in the cyclone, the larger the particle size cut point that passes through to the shop vac becomes. Since we aren't told by the seller what the engineering specs on the cyclone are to begin with, it makes it difficult to optimize the system for efficiency.
$156.88 $11.12 per Ounce ($11.12 / Ounce)TEMCo toe jack in prep for moving the 6,600 lb bed mill into it's permanent spot.
From a video recommendation for spindle angular contact bearings. A forum member posted a link to the video, apparently the video guy rebuilds spindles for a living.
