- Aug 19, 2023
- 1,314
With the steady rest.... Might want to look at the brass tips. Either smooth them out, or replace them with..... Yup, you guessed it, either delrin or roller bearings. Currently working on that particular issue with mine, then I will tackle modifying the foot so that I can use it. Will see if I can do the milling with the milling slide since the steady rest is an aluminium casting, or so it would seem. There are also a couple of other "mods" I would like to make too. Will have to see about a thread about it when I get around to it.
Yes, the "Factory" fixed rest is awful. Yes I have one and yes, I have used it. Once. On a small job. Wish I had not bothered, it was nothing but a pain in the rear end. The "following" steady is just as bad, but I intend to use it as a base for a modified rest.
The bigger fixed steady proved far more useful for the fact it can be opened. The one you have was purchased already modified as a test to see if it would work out. It did, so I purchased an un-modified one that I can do myself.
