- Aug 9, 2023
- 480
that's a casting. Some had copper or bronze inlays..
The temporary workbench it's temporarily going to just sit on is a cheapy thing, but should handle the static weight. I wouldn't dream of using the mill on that bench though.RF 30 clone, you can do good work with that. I had one branded Harbor Freight, it’s pretty heavy so make sure your workbench is up to it.
John
Nah, the Analine isn't much use in the shop except as a feedstock. There are ways to cook that stuff into explosives or drugs, but not very convenient for the hobby machinist. It's the starting point for anodizing dyes, but really a lot of steps short. The CCl4 will utterly destroy your kidneys and liver, but it's the simple chems that are the most useful and the most toxic. That's the physical universe for ya.Which one? Analine? I don't know of any good uses for that. We used to use CCl4 to wash out glassware.
That one is a little different, it's cyclohexene. Also a feedstock for reactions and not useful in the shop.Why does that Cyclohexane say solubilized with NaOH? I wonder what it's pH is?
Hmmm. I wonder if that would have enough 'kick in the pants' blast me off my rear to get something done around here...There are ways to cook that stuff into explosives...
Not with this HEAT !Hmmm. I wonder if that would have enough 'kick in the pants' blast me off my rear to get something done around here...
Yeah, it's hot here today too (It's 70F).Not with this HEAT !
Best way is with an accurate outside temperature and a set of gauges that will read the high and low side. Then you just add until you're in band on the pressure/temperature chart for your given refrigerantSo speaking of heat , I have to re-charge my AC units on the F-250 and the Civic . I've recharged older vehicles but not these newer vehicles . Heard you could do damage if you don't know how ( which I don't ) . I believe hooking up the bottles on the lower point with the AC running and fill to the air inside gets down to 45 degrees . Is this correct ?
