Recently picked up my first mill. A Bolton Tools ZX32GP (A ZX32G with a power feed standard) which is similar to a PM-727M. It isn't anything special, but the price was right and it came with a few accessories such as a stand, clamping kit, vise, set of end mills, two axis DRO kit (not installed), parallels, ER collet adapter. As I understand it, the previous owner purchased it years ago and passed away. This seems further supported by the fact the mill had no feet installed for the stand, and the vise only opens an inch or so due to the leadscrew being bent. That vise should have been returned.
Some notable items:
- The column to base connection was covered with Bondo when it was being finished. No seam is visible for tramming the column if needed.
- The leadscrews appear to be true inch.
- The ways are all flaked. Machining on the ways leaves a lot to be desired.
- It came with some plastic shield that flips out of the way when making tool changes. It has a safety switch that forces you to close the shield. I pulled that off and will see about disabling the switch. If anything, it may be a good spindle lock safety if I go that route one day.
- With the help of HM, I ordered a Tegara 440V vise as a replacement.
- I have some leveling casters on the way along with some collets, clamping bolts for the X,Y,Z axis (Y axis ones are missing), Edge Technology indicator holder for tramming,
