Yours look good to me. I would be just fine with that.Here's a couple of pics of mine. All appear to be the same.
I put a depth mic on the HSS to the block, top and bottom measure the same stick out.. so square as far as I am concerned.
That's a piece of MoMax HSS, I checked it for square, and it is.
The light under the tooling is really there on the ones I received, even though it is a poorly taken pic and the focus accentuated the amount of light , the floor is just not flat, contact is made only on the outer edge and inner corner edge of the tooling I tried, even with square tooling moved out from the wall. Greennmood (I misspelled it in previous posts) is just a different china? tool holder seller on ebay. Their BXA set was about $180 for an 11 piece set doing the same light test with the same cutter no light is getting under the tooling and does not exhibit the slight rotation of the tool to make contact with the outer floor edge when tightened down. It just sits flat, like the pics of yours.
No biggie. Sorry for thread drift.
Another purchase on the way. I want to modify my old TLB to have a hydraulic thumb on the backhoe. So a Rube Goldberg idea to be tested.
Already added the mechanical thumb a year or two back. But is a beast to pin and re pin it weighs almost 120 lb
Don't have a power beyond available so going to try this self contained 12 volt pump/reservoir
https://www.vevor.com/hydraulic-pow...Pyvr4oeIIhpHnWhULNQ4v5Vi8eB8mNPxoCrVcQAvD_BwE
and a 3" Bore x 16" Stroke double acting cylinder
