Success with the heat treating and boric acid.
My practice was this center to use with my dividing heading head. Here is the center:
The boric acid has worked great preventing scale. It does create an almost glass like coating on the surface. A lot of it flakes and cracks off after the oil quench. I managed to stab my finger on the shards. What's left is really glued to the piece. I found the key to removing it:
baking soda in hot water!
Works like a charm, like the Efferdent commercial. I little 0000 steel wool cleans up.
It can be a little tricky getting the boric acid to stick to the piece. So far I've just made a paste and tried to get it to stick. If you get it right it melts in the oven and prevents scale. Apparently, you can also heat the piece up and get the powder to melt/sick. Will try that next.
Here is the center in a mount that I'm going to bolt to an angle plate when needed:
Can you post a shot of the title page or more info for that book? I found two possibilities, and would love to have copy.
-Dave
