Ultra Quiet Air Compressor
twstoerzinger
Nov 13, 2012
165
My basement shop is about 14' x 14'. I don't use much compressed air, just a little for occasional gentle clearing of chips from holes, but mostly for the power drawbar on the Bridgeport. I had been using a portable 3/4 HP oil-less compressor that I have had for 30 years (it refuses to die). The problem is that it is REALLY noisy. It only starts occasionally with the light duty it has. Several times in recent weeks it decided to roar to life just as I was touching off on the lathe or mill - and made me jump big time. I decided it was a safety hazard and looked into more quiet compressors (I was able to sell my wife on the safety hazard thing.)
There is at least one manufacturer that uses refrigeration type (oiled) compressors. They make no more noise than a refrigerator, but they cost about as much as a new fridge.
I found another outfit in California that markets a Chinese built "ultra quite" compressor. The company is California Air Tools - I think they also market under the GMC trade name. The one I bought is a 3/4 HP portable with an aluminum tank. It weighs about 35 lb. Twin cylinder, rubber mounts, 1.5 cfm @ 90psi. The manufacturer claims it is only 58 dB of noise. I have no way to confirm this, but it is really quiet. Two people can have a conversation right on top of it without having to use raised voices - I think my bench grinder makes more noise. The compressor cycles between 90 and 120 psi, so I can leave the power drawbar regulator set at 80 psi and always get the same torque. When the mill or the lathe is running, I can hear when the compressor starts, but it is strictly background noise and is not a shocker. Turns out Home Depot is a dealer for this compressor - but you have to order it over the internet and have it shipped to your home (free shipping). I think I paid about $170 (on sale) + MN sales tax for it. So far, I am very happy with it.
If you need a smaller compressor with low noise - you may want to consider this one.
Terry S.
I had an attic space to put the noisy Campbell Hausfeld. Had to put some 6" air tires on it to damper the vibration. It's been there 20 yrs with an annual oil change and frequent tank draining. Didn't know there was such a thing as a quiet compressor.
I recently purchased a little 6 gal/1hp compressor from California air tools and love this thing. So quiet I put it under my hand work bench and it doesn't bother me at all. Well, the little 'psssssst' when it shuts off startles me sometimes because I forgot it was running.
These things are made for use in dental offices and I think the sound level spec is ~60db. My daughter talks louder than that... ;)
Bill
Some years back I removed the sealed compressor from an old window air conditioner, and added a pressure switch and an old disposable refrigerant tank. Nearly silent, could go as high as 220 psi. Low flow, of course, but sufficient for my needs at the time.
You'll surprised at how much quieter you can make a compressor if you just pipe the air intake outside I don't know if you can do that in your application or not
Terry, thanks so much for that recommendation. I've been looking for a quieter shop compressor, and so far I've found one made by Arbe, marketed by Gesswein. You can see it HERE. They say it makes a sound level similar to a residential refrigerator. But at $795.00, I think I'll have to pass. The line of compressors you tipped us off to look like just the ticket for my shop! I think we all know how we guys get focused on our work - I've had my compressor decide to turn on right in the middle of a delicate operation before, and it's not pretty.
Thanks Terry!
...Doug
How about just building a box with Styrofoam insulation to make any of them quiet?
Depending on how you do it, it might work to some extent BUT I'd be concerned about air flow around the compressor and it over-heating.
-Ron
WHOH! That's a great idea! No way!
Bernie
