Trying to identify/locate a part
ltlvt
H-M Platinum Supporter
Aug 29, 2019
1,259
I am trying to locate this part for my 30 hp Kohler engine on my Dixon Grizzly Mower. I have bought it in the past but I can't find the part or the name of the part now. You can see it on the bottom right side of the picture. It is actually a little rubber cap that is a split cone shape. the one in the picture is bad. Seems with age they turn from soft rubber to gum. The function it to keep the filters inside the housing clean. Don't ask me how this little rubber thing does it but it does an excellent job. The engine will run fine without this but the filters will get pretty dirty without it. I have had this mower since 2008 and the filters still look like new I have new ones but have never put them in because this little device keeps them that clean. So does anyone know what the part is called and a possible source. Thanks in advance.
Dust ejector valve?
On Amazon, but you have to validate engine serial to make sure you order the correct size
And this one is original part, again, check engine for correct size before ordering
FridayParts 2446207-S 24-462-07-S 24 462 07-S 11065-7008 15518 Dust Ejector Compatible for Valve for Kohler Kawasaki Engine Replacement (1)​
$6 on amazon
I saw that one, but was not sure if it was the same size for the 30hp engine. If you look closer, 5.90 for one and 7.20 for two...
Absolutely grateful for the reply. I will get it on order today. Knowing what to call something is 90% of buying a replacement now days. I am very appreciative for the help. Thanks
don't you guys sleep... geez. Jaime, I see you often in the middle of the night... wth
I have to go peeeeeeeeee! LOL :D. I think that I have overshared before...lol
No time is wasted…
