- Aug 7, 2018
- 668
Nice job on your tool holders. My boring bar holders are are a little on the rough side but work well. Mine also take only a 1/4 turn to go from free to locked. I have been using the two boring bar holders to bore the center holes on the remaining five holders. I have decided to complete one holder as a test run. I will try cutting the slot with just the end mill without drilling out most of the material to see how that works for me. I can hold all of the last four holders in my vise at one time.
That way I can cut the slot in two of the holders at the same time. Then do the other two. I have been using the slowest speed on my mill in previous projects. For this I think that I will figure out what speed I should be using and see how that works for me.
Thanks for the picture. Be very careful holding several pieces like that in your vise. I personally would not do that. You cannot guarantee that the work pieces have faces flat enough to grip each other. At best I would only hold two, and even then use some cardboard between the vise faces to ensure that they were both gripped securely. Also tap them down so that they are sitting flat on the vise bottom.
