- Oct 31, 2016
- 2,721
You can make these anyway that you want to. Doesn't seem to matter. I have done several different styles. I have found that you don't need the 45* angled cutout. I made the cut outs with an end mill. Nothing special. First milled out the flat portion. Then clamped the holder in the vise at a 45* angle and milled the angled portion. Just leaving it squared off seems to tighten just as easy as with the cutouts. I will not make the cut out in any future holders that I make. Takes 1/4 turn with the wrench to go from loose to tight.
5/16 bolts are the smallest you can use. I tried 1/4 bolts and twisted the head off trying to get it tight. 3/8 bolts work the best. If you do make the cut out you have to be very careful with the position of bolt. You have to have enough clearance for a wrench to fit on the bolt.
I have found that 1/4 set screws are sufficient to hold the tool bits. I used 5/16 set screws to start with. The most recent ones that I made have all been 1/4 set screws.
After Mikey schooled me on the forces and geometry of parting I made a special holder for parting. It sits on the base. No height adjustment screw. I used to be parting challenged. With my new parting holder no more problems with parting. Winky's Workshop has good videos on making a parting tool holder. I followed his design.
I found that you need a nut on the height adjustment screw to lock it in place. Otherwise it will move with vibration and handling so you loose your height and have to reset the height. And you have to be careful with the position of the height adjustment screw so that you can get a wrench on the nut to tighten it. You also don't need a 1/4 screw. There is no load on the screw. A 10/24 screw will work just fine.
I have made 12 holders so far and plan to make a couple more. Including a knurling tool based on Mikey's design.
