Man... the details take a lot of time. I spent half the day making the vernier "zero" marker for the rotary table base.
This is the finished marker installed. Yes, I made another mistake
. I miscalculated the width needed and only got the 4 lines. No room for the fifth, but it is not needed anyway and with the hours in this one, I wasn't doing a "do-over" if I did not have to. The fourth line is right at the outside edge on each side. Amazingly it does work. This will ket you "eyeball" a pretty close setting, but if I had to be exact, I would use an indicator anyway.
Here I am machining the radius for the vernier to fit around the arc of the table. There is probably some easier way to do this , but I work with what I got, so , I put a block of steel in the four jaw chuck and set it for 1/8" larger radius than the table and started whittling away at it.
a few hours later, it is done (on the inside).
I used a radius-ed cutter to get a nice finish on the outside bevel. ( I used carbide just because I already had the cutter and didn't have to grind one.)
You can just see the end of the boring bar used to engrave the lines. At this point while it is set up it was best to go ahead and put the lines on. I put my degree wheel on the spindle and engraved a line every 4 degrees on both sides of zero. The fourth line is right at the outside edge of the cutter. I wished I had room for the fifth line but it is not needed anyway.
this is what it looks like right out of the lathe. I cut it to length in the band saw and then put it on the mill for finishing.
About an hour on the mill to cut the key on the back, clean up the sides, an angle the bottom and it is ready to mount on the grinder as seen in the first photo.
