I been chasing my tail all day on this tool holder. It is built, looks great and works smoothly, BUT, I decided to do some checks and got out my trusty indicators. It seems there is a few thousandths run out in the tool holder spindle when I turn it. no end play just a little TIR. I know there is .002" clearance between the the spindle housing and spindle. This could and probably would account for some of it. I took the spindle out and put it in the lathe with a 4 jaw chuck. indicated it true by the chuck, put my steady rest on the outer portion and indicated it true. Now the spindle is turning true. I checked the taper for the 5c collet and there is .003" run out. so i skim cut it true and all indicates true. So I put it in the tool holder and checked it and I still show .004" run out when turning it. Now, I realize this really won't hurt anything sharpening the ends of en mills and sharpening lathe bits, and this holder is not meant to and will not work for grinding flutes, but it is just frustrating . Something else I have noticed. When you rock the tool holder in and out as you would when grinding, it moves several thousandths. with everything locked down you can flex this whole setup easily by hand several thousandths. Chances are no one has ever checked this. If I rock the assembly as in grinding and hold it near the base and micrometer bar, you don't see this movement. This indicates to me to do something I have been thinking about. Making a handle that clamps on the front bar to use to rock the tool in and out. this will solve the flexing when holding it and also make it easier to operate and the handle can be moved to any location desired on the front bar.
It seems most of the flex when handling it comes from the 5/8 bar that the tool holder mounts on. Anyone got any comments or ideas or am I just being fussy.
