Busy day in the shop today. I feel great because I am almost finished wit the lower half of the work head. It is great because I think this maybe the most difficult part of the build.
I started by machining the spindle for the rotary table. I cut the 1/2" post , then put it in a collet to finish. I machined the 90 degree seat and finish milled the top of the spindle. The reason for putting in a collet to finish was, it is important that the seat, the reamed center hole, and the spindle shaft are all concentric to keep accuracy. the table needs to rotate exactly on center.
This is the finished spindle. If you look close you will see my major screw up. there is a .187 spacer on the large end of the spindle. this is because I misread the prints and miscalculated the depth and cut the underside of the table too deep by a quarter inch. This would require the need to remake the spindle if my repair was not successful, but it seems "revision 1" may work.
To make the 3 inch rotary table, I chucked up a chunk of 3" diameter mystery steel ( I think it is CRS). After turning .010" off the outside to clean up, I started what I knew was going to be the hardest part of this build. cutting the T slot in the table. The prints show making it in two pieces and Loc-tite them together. I have no doubts that this would work and would recommend the two piece method for anyone not well experienced. I started by making the .312 slot .250" deep using a parting tool. It took four plunges to get the slot cut and halfway cleaned up. Now you will notice the crappy looking ugly tool in the holder. it is for cutting the "T" in t-slot. I quickly ground this on a new piece of 5/6" HHS. If I owned a tool grinder, I could have made a nice one :rofl:. There is another one on the other end that is the reverse for cutting the other side. I thought I could cheat and just grind one, then turn it upside down and reverse the lathe. DO NOT TRY THAT! It went bad and was really ugly, so I ground the second end. Turning the T slots was very difficult and took a long time, but I am glad I made the table in one piece.
This is another view of the ugly tool.
With the T slots cut ,it is time to bore the center hole for the table spindle. This hole was bored to a snug slip fit for the spindle.
After boring the center hole , I started machining out the underside of the table.
This is the finished table. THIS IS WHERE I SCREWED UP! I misread and miscalculated the depth of undercut on the rotary table and machined the underside .250" too deep. There is NO WAY I am making this table over again so it is time for "revision 1". I could remake the spindle and compensate for this mess, OR make a spacer. I opted for the spacer because once it is loc-tited in there, it will stay. I will also make a brass insert for the recess left in the center of the top because the spacer dropped the spindle .187". That will be "revision 2" and all is good again :rofl: ( see , there are no mistakes, only revisions :nuts
This is the top of the table. It will get finished machined after the spindle is loc-tited and the brass insert is put in.
The spindle is permanently affixed into the table with loc-tite so the spacer worked.
I almost forgot this detail. a notch is machined in the table so T nuts can be inserted.
One last detail today. I made the lock bolt for the tilting block so I could assemble everything to check the fit.
This is the lower half of the work head, temporarily assembled to see how it looks ( and to make me feel good). I painted the front and rear plates with the black wrinkle finish. I am happy with the look.
