Could you make a note on the base drawings of your comment about leaving them 2"? I'm liking this idea.
It is starting to sound like a person should stare at the drawings long enough to get an idea of what they want to do and then just go their way. Like you and Bill did.
Yes, I will do that.
You are correct. If you have a set of drawings try to look at them, they will drive you nuts:nuts:. They were made in Britain ( they use a different perspective than us), converted from metric to inches in Australia, and a lot got lost in the transformation. they are riddled with errors and you have to stare at them for hours to figure out what is going on.
anic:You will be like this little yellow guy after a while. I have more hours trying to figure these prints out than I do in the actual build.
I found no two builds alike , so yes, everyone does whatever they want ( probably couldn't figure out the prints)
I made a lot of changes and found out when you change one thing , it screws up everything else and you have to compensate for it.
I made my sliding base bigger and heavier, but this altered the dimensions for everything. I am glad I did it though.
I lengthened the bed from 12" to 19" and this is almost a necessity.
I changed to 5C collets for the work head and this required redesigning the whole work head.
I am making a set of edited prints to match what I am building and you will be welcome to a set of them , but I use a lot of scraps or what I can find and this meant things were changed to fit what I have. this is not always what is best. I make no guarantee of my prints, but they sure as heck are easier to follow.
