I turn to the considerable experience of the folks at HM.
My questions is, should I cut and thread big holes using my lathe tools or should I just buy a 1.25 x 7TPI tap? Can I even turn a tap this big?
@WobblyHand I see that you have cut threads this size using an ELS modified lathe. So maybe you have an opinion?
I have not cut heavy threads in steel so I thought I would ask for advice. I have never had the need to cut such large large threads but I may need to do so in the near future. I want to have some threaded holes in 0.75 inch thick (TBD) construction grade steel plate (A500?) to receive 1.25" by 7TPI threaded rod. These are for some special steel post I would like to make which would have two threaded rods inserted in one end and one threaded rod at the other end of the post. (Three holes per post.) I may have the tooling to cut such deep threads as I have a 5/8" boring and turning set from PM. I have the standard PM1440GT tool post holder plus a BXA Tool Post etc.
I have a PM1440GT lathe and a PM940M CNC mill, but most of my projects have been much smaller parts than this one. I will need to make two holes in one plate that fits into a steel post and one hole in the plate at the opposite end of the post. Each "pair" of holes are offset from the center. The single hole would be centered. The plates will probably about 4"x 3" or 4" diameter depending upon which tubes/post are readily available. I will need to repeat these two plate builds 4 times (12 threaded holes).
Dave L.
Dave L.
