Helicoils are absolutely terrible for holes that have bolts removed/installed every day such in a fixture of an industrial machine that is changed over to different part types. Other than being cheap, there are much better solutions and have been for 30 years.I am reading alot of stuff these days throwing rocks at Helicoil. Especially spark plug threads in aluminum heads.
I ain't done a bunch, but I have been using Helicoil for my whole life for lots of applications. So far, so good.
I don't like the non-standard thread form on the outside of the Keenserts. It cannot be as strong as the full 60⁰ thread on the E-Z Lok. I'd plan to drill the hole a few thou tighter on the E-Z Lok OD for greater thread contact rather than less.Helicoils are absolutely terrible for holes that have bolts removed/installed every day such in a fixture of an industrial machine that is changed over to different part types. Other than being cheap, there are much better solutions and have been for 30 years.
The best inserts bar none are timeserts. They are wonderful in every physical way, thin walled, strong, durable, just not cheap due to the tooling.
Ez-lok have a lot of knock offs, many that are of softer metal, beware of that
Keenserts(AKA CatSerts as they are caterpillars prefered method) are the best solution imho for strength to cost ratio. If you have the space, they are as durable as timeserts, lock in place mechanically, and use standard taps/drills for install. You don't need the special tool even to drive in the locking pins if you are careful/talented with a punch.
I think your tilting at windmills. The crest and root of most SAE threads are done for production, not strength A rounded crest and root eliminates stress risers. Removing the tip is inconsequential as its mostly a stress riser anyway. Look at whitworth or Unified J threads how they round over the crest and root for improved strength.I don't like the non-standard thread form on the outside of the Keenserts. It cannot be as strong as the full 60⁰ thread on the E-Z Lok. I'd plan to drill the hole a few thou tighter on the E-Z Lok OD for greater thread contact rather than less.
I could be wrong.....
I spent a good deal of time looking into thread repair inserts today. I don't like the idea of needing lots of special taps to use Helicoil type inserts so I'm leaning toward the solid inserts like the E-Z lock type. I know the Helicoil type inserts are quite strong.
I simply want to but a few sets of inserts to put on the shelf for general use without needing special tools. I think that is a pretty easy request.First off, what are you doing with them? What material, what job will they be doing? There really isn't one fix for everything.... If you don't have that answer..... STIs / Heli Coils. They're the most versatile, most forgiving of mediocre hand installation or damaged materials (Unless you HAVE to remove too much material for some reason...). Plus Heli Coils can be cut short for thin materials without compromise, they can be "stacked" without compromise should you not want to order out for the correct length, They're just the most universal, and when put into reasonable joints in reasonable materials, they still exceed the strenth of the parent material, and the strength of the bolt, which is about all you can hope for, right? Yeah, it's extra taps to buy... one set does 99 percent of anything that needs threads. And when you really want another type of insert, Plastics, Wood, Plywood..... Well, you won't exceed any bolt strengths probably, and there are yet more special inserts for that, but you'd be surprised how well a heli-coil can do there too. So if you're just making up a kit to be ready for the unexpected, STI is my recommendation.
Another similar video on the subject- Crazy strong bolts though, testing the inserts in cast iron.
I'm not NASA and I'm not fixing 5000 hp engines. I'm repairing farm equipment and goofing off in my garage. $10+ each is ridiculous for the repairs I would need them for.I think your tilting at windmills. The crest and root of most SAE threads are done for production, not strength A rounded crest and root eliminates stress risers. Removing the tip is inconsequential as its mostly a stress riser anyway. Look at whitworth or Unified J threads how they round over the crest and root for improved strength.
In addition, the thickness of the wall and the larger thread contact of the outside threads of the inserts are so much larger than original fastener size that again its inconsequential. The superior heat treatment and quality of keenserts is apparent to the ezlok.
Do you really think that FAA/US military/NASA would approve keenserts for flight above others if they were inferior? Or Caterpillar only recommend them for critical repairs in 5000 hp marine engines?
First, I am sorry, yes keenserts are about 2-2.5 times more expensive than EZ Lok inserts, and yes, on moderate and low load repairs, they are sufficient.I'm not NASA and I'm not fixing 5000 hp engines. I'm repairing farm equipment and goofing off in my garage. $10+ each is ridiculous for the repairs I would need them for.
The extra thickness would also be a nightmare on lots of stuff I'd actually do. I don't know what will come in but some things don't have much wall thickness.
Finally I can't afford to have several of each on hand for the next time an Amish farmer drags in a part that he needs to finish feeding his cows before he can go to bed.
