thoughts on making suppressor core?
Here is a monocore design that is simple. Been saving this idea to try later...
Sent from my SM-T800 using Tapatalk
I agree with the suggestions on cones or "K" baffles. Easy to turn on the lathe. Work better for 9mm.
Here's one simple design. Just stuff several into a can that screws closed.
I've made a couple of Form 1 suppressors already using 60* cones for rifles. They work great, especially with the right 'clipping'.
The reason behind wanting a monocore is that I need to permanently attach it to a short barrel, to bring the barrel length up to at least 16" so I don't have to register it as an SBR. A monocore can be built and attached, and just a removable tube is used, remove the tube and clean the baffles.
