- Dec 25, 2017
- 167
I have had a 1-inch Delta belt sander for 20 years. It gets a lot of use but my projects have out grown it.
Specifically I am planning to build a stainless steel exhaust system for my F100 and need to true-up band-saw-cut miter joints prior to TIG welding. I want nice tight seams. Seems to me a 4-inch belt grinder would work well on a 2 to 3-inch 14g 304SS pipe. I also have a lathe stand to build out of 2" square mild steel tube with mitered and welded joints.
I have been hunting around and this Jet unit seems a good compromise of what is needed to be my belt grinder for the next 2 decades and the need to control cost.
It has a 1 HP motor and a fixed belt speed of 3769 SFPM. A variable speed version is available for $250 more. Is variable speed worth that?
So what are the pros and cons? Other tools out there? Grizzley has some interesting stuff but the shipping makes them much more expensive than the Jet.
Of course I COULD build one but that just becomes one more project in the way of getting to what I want to do. I already have projects stacked up to my time horizon.
Another alternative that costs nothing is to square up all the miter joints on my mill, using a 4-inch long cutter. That seems doable but is likely to be unwieldy for longer pipes and not-straight sections that need trimming. (EDIT: Also could get dicey for very short pieces and pie-cuts.)
I turn the floor over to you. Thoughts??
Jet Combination 8 in. Industrial Grinder and 4 in. x 36 in. Belt Sander 1 HP 115-Volt, IBGB-436 578436 - The Home Depot
The IBGB-436 Combination 8 in. Grinder and Belt Sander is engineered with industrial strength construction, sealed bearings, and a powerful enclosed 1 horsepower motor meant for heavy usage. The combination
www.homedepot.com
