Ah... I'll check as it's been 2-yrs since I bought something from TechEdge. I've been using their products for 30-yrs back when it was freeware/open-source project. About 10-yrs ago, they retired their discussion forums which was very helpful for Q&A with tips from other users. I've been looking at an all-in-one unit with on-board datalogging and display I can make portable for use on racing moto-bikes. Push one button to start datalogging, do couple laps, then come back and dump logs to laptop to draw pretty graphs for analysis.
As long as you're maintaining factory specs and performance from car, easiest to maintain as much stock configuration as possible. Least effort that way. Hoard or update most problematic parts.
Toyota had some '80s standalone ignition-systems I've adapted to CIS-based Porsches. So powerful that spark will actually jump from inside of ignition-coil-terminal to outside ground bolt if distributor wire's not plugged in!
What I've been doing lately on old moto-bikes is converting distributor points-type ignition systems to COPs. Get Ford EDIS ignition-modules from junkyard. Use factory distributor points to trigger EDIS. Points are no longer high-load and lasts forever and you get high-power wasted-spark ignition.
