[How-To] The Whatever Project, is it appropriate for here?
Started working with the new wiring harness. Well, working with it is a stretch. More appropriately, I've taken a dvm to it. So I think that I have figured out which wire is the main feed and which is the accessory feed, both the same color, one direct from the battery, one from the accessory terminal on the ignition switch. And getting it sort of matched up with the Austin Mini steering column switch assembly. You know what they say about British wiring? Lucas Lord of Darkness!
