- Jan 6, 2017
- 1,232
You guys have to recalibrate your Z offset when switching between ABS and PLA?
I've been printing ABS, and yesterday switch to PLA on the Voron. I had to recalibrate the Z endstop to get the PLA to stick. Before recalibrating, it was just dragging around a glob.
After printing PLA awhile, I forgot to recalibrate and when i started printing ABS again, the nozzle was just barely touching the bed, without enough gap for the ABS to leave the nozzle. I had to recalibrate again.
With my Flashforge, it seemed to use the same offset for a 110c bed as for a 55c bed. The Voron bed seems to expand up and fill about .2mm going from 55c to 110c. That seems a little much.
Using the coefficient of thermal expansion for aluminum, it should only expand max, about .002mm for a 55c \
Edit: I did the calculations using .000023mm per mm per degree times 55c delta temp, and came up with .0101mm of change. So, yea, I'll have to do a bed mesh, or further loosen 3 of the screws that hold down the bed. It must be bowing a little when it heats up. 55c shouldn't swell it enough to fill the .2mm gap i have it calibrate for.
I may consider doing a mod to mount the bed the way my flashforge is, with springs to allow for expansion without bowing.
