I picked up an old Craftsman hand drill motor stand/press at the swap meet for $5 missing most parts. I just used the pedestal and upright with a AL block with a 3/4" rod thru it to make mine. Works great for getting em started at 90 degrees.
Not finished but usable. I made decisions on material at hand & may make some changes/improvements when I have the right stock.
The arm I made in 2 pieces because I thought the main portion of it was too thin to be real rigid on the round post. If it were one piece I would have more adjustment in the sliding bushing.
The round post makes it radial and is convenient as I was able to use it to tap holes in the base after assembly. It also allows for height adjustment.
The driving rod is a really long 3/8 extension that works well for now but may be upgraded later. Right now the wheel is just sitting there for mockup, I actually used a breaker bar to drive it while tapping the holes in the base.
I was going to mill out a section in the center for the tap to go all the way through but instead the part will lay on 2 parallels.
